2022-04-17 07:20 PM
2022-04-22 02:12 AM
Hi @KHuan.8,
Indeed, we are experiencing issues with the link you mentioned and a couple of other ones since a few time. We do apologize for any inconvenience caused.
As a solution, you can use CubeMX to download the firmware package of your choice with, inside, the desired version of the STemWin library. Please find more details here.
I hope this helps. Do not hesitate, should you face any problem.
With regards,
2022-04-21 07:35 AM
Hi @KHuan.8 ,
You should be able to download STemWIN from STemWin - Professional graphical stack library enabling the building up of Graphical User Interfaces (GUIs) (AN4323) - STMicroelectronics.
Do you confirm that it works properly or there is an issue?
I add @ALABB in the loop to fix the link in GitHub side.
-Amel
2022-04-21 06:04 PM
Hi @Amel NASRI ,
Thanks very much for your information, the link you provided is worked and I can download the STemWin , but the version is 5.32 which is different with the GitHub mention as 5.44.40, I am not sure which one is correct?
2022-04-22 02:12 AM
Hi @KHuan.8,
With regards,
2022-05-01 07:07 PM
Hi @ALABB ,
Thanks very much to answer my question, I can use the library now.
Please close this ticket, thanks again.
2022-05-04 03:31 AM
Hi @KHuan.8,
Really glad to read your reply. I let @Amel NASRI close this thread.
With regards,
2022-05-04 05:11 AM
Thanks @KHuan.8 & @ALABB for the follow-up.
In our community, a question is closed when a Best Answer is selected.
This is what I did selecting @ALABB 's answer.
-Amel
