Have anybody QSPI loader algorythm for Keil?
EEuge
I can't create workable code....
https://www.keil.com/pack/Keil.STM32H7xx_DFP.2.7.0.pack
Tip: It's a .ZIP file...
12 REPLIES 12
MM..1
Chief II
When you have installed stlink utility try read readme.txt in
c:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ExternalLoader\MX25LM51245G_STM32L4R9I-DISCO
here exist too keil project...
EEuge
I want for STM32H743 and MT25QL
thanks for link, a used this sample when I worked with F746 and w25q - without problems.
But H743 and MT25QL.......
void QSPI_WriteEnable(void)
  QUADSPI_ComConfig_InitTypeDef QUADSPI_ComConfig_InitStructure;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_FMode = QUADSPI_ComConfig_FMode_Indirect_Write;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_DDRMode = QUADSPI_ComConfig_DDRMode_Disable;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_SIOOMode = QUADSPI_ComConfig_SIOOMode_Disable;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_DummyCycles = 0;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_ABSize = QUADSPI_ComConfig_ABSize_8bit;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_ADSize = QUADSPI_ComConfig_ADSize_24bit;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_DMode = QUADSPI_ComConfig_DMode_NoData;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_ADMode = QUADSPI_ComConfig_ADMode_NoAddress;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_ABMode = QUADSPI_ComConfig_ABMode_NoAlternateByte;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_IMode = QUADSPI_ComConfig_IMode_1Line;
  QUADSPI_SetFIFOThreshold(0);
  QUADSPI_SetDataLength(0);
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_Ins = WRITE_ENABLE_CMD ;
  QUADSPI_ComConfig_Init(&QUADSPI_ComConfig_InitStructure);
  while(QUADSPI_GetFlagStatus(QUADSPI_FLAG_BUSY)==SET);
sprintf((char *)str, "WR1:  0x%08X   \r\n ",QUADSPI_GetFMode());
			       HAL_UART_Transmit(&huart7, str, strlen((char *)str), 3000);
  QUADSPI_AutoPollingMode_Config(0x02,0x02,QUADSPI_PMM_AND);
  QUADSPI_AutoPollingModeStopCmd(ENABLE);
  QUADSPI_SetDataLength(0x00);
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_FMode = QUADSPI_ComConfig_FMode_Auto_Polling;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_DMode = QUADSPI_ComConfig_DMode_1Line;
  QUADSPI_ComConfig_InitStructure.QUADSPI_ComConfig_Ins = READ_STATUS_REGISTER_CMD;
sprintf((char *)str, "WR2:  0x%08X   \r\n ",QUADSPI_GetFMode());
  while(QUADSPI_GetFlagStatus(QUADSPI_FLAG_SM)==RESET);
  QUADSPI_ClearFlag(QUADSPI_FLAG_SM);
  QUADSPI_ClearFlag(QUADSPI_FLAG_TC);
	sprintf((char *)str, "WR3:  0x%08X   \r\n ",QUADSPI_GetFMode());
it halts on
On what pins? Don't they have some in the "Packs" directories for the H7 related to the EVAL or DISCO boards?
C:\Keil5xx\Arm\Packs\Keil\STM32H7xx_DFP\2.7.0\CMSIS\Flash\STM32H747I_Disco_QSPI\QSPI
C:\Keil5xx\Arm\Packs\Keil\STM32H7xx_DFP\2.7.0\CMSIS\Flash\STM32H7xx_MT25TL01G.FLM
The QL's should be a relatively short walk
Your second link is for MT25TL01G, but I have MT25QL128
Yor first link - my DFP version is 2.4.0, updater list contains onl 2.5.1. Where you got 2.7.0 version?
Folder STM32H747IDisco_QSPI\QSPI contains SOURCE or .FLM?
My pins
Source code/project, the top level has .FLM's
Using MDK 5.33, pulling most current packs itself.
Sure, but you were looking for working examples, and this should be relatively close, the QL128 only needing 3-byte addressing. These are half a dozen or more examples under the CMSIS\Flash trees.
I could code something exact if the bounty was compelling.
Can you attach Source with project here?
