2020-04-24 11:13 AM
Hi there -- I have successfully got the TouchGFX interface and HTTPServer Example (LWiP) working on a STM32F769i-Disco however, as I'm adding more things I seem to be having issues with the stack size and/or memory.
**Please note: in the attached image you can see the toggle button renders correctly, but all the other buttons and textfields are low resolution. Is this a memory issue? Why would adding the ethernet buffer code cause this.
Here's where I'm at right now:
I can have both working (touchgfx displays properly), however, the HTTPServer the request takes 30 seconds to return -- it's stalled or hangs, then resolves and displays properly.
I think it could be related to a memory setting issue in the RTOSConf?
Any idea what could be causing this? I'm new to STM32 dev.
Thanks!
2020-04-25 01:57 PM
2021-08-28 06:54 PM
@DMavr.1 did you sort this out?
I am quite a few steps behind you, still trying to figure out how to get touchgfx and LwIP working together.
I was hoping you might be able to post some of your code and CubeMX configuration so I can see how you did it?
Thanks in advance,
Greg
