CubeIDE 1.0.0 + TouchGFX 4.10.0: Working project inside (STM32F746G-DISCO)
‎2019-05-27 4:06 AM
Hello everyone,
Due to an increasing number of people having issues with CubeIDE and TouchGFX Integration i'm attaching a working project for STM32F746G-DISCO for your inspection - There were a good number of things to do before it worked, only some of which i highlighted in my quick-guide and even some of those steps were a bit ambiguous and could be executed in different ways.
I've written down what i've done to get this project working and i will use this in planning a video tutorial - It has to be somewhat official, so i can't simply start up the screencast and start talking. But i'll keep you updated.
/Martin
STM32CubeIDE
STM32CubeMX
TouchGFX
‎2019-06-03 1:43 AM
It's a sticky now in the TouchGFX sub-forum.
/Martin
‎2019-06-03 1:51 AM
Ah ok I didn't see you updated it. Thank you, I'll watch it !
‎2019-06-03 1:58 AM
I could have been more explicit about it :) It's difficult to update everyone when you simply do an edit - Maybe have created a new post that i'd modified the sticky post, but that is also a bit excessive, i don't know, haha.
‎2019-06-03 1:58 AM
I hope you find it useful! some people have reported issues with the resolution being too high (I suppose when watching on low res devices). Let me know what you think,
‎2019-06-03 2:51 AM
​Hi Martin!
Thanks a lot for that video and all your work to help us doing the right things to get the code compiled :-)!
I had the same problem with the resolution like told later on by other community members (LCD Resolution Standard Office 1920 x 1200 Pixel), so sometimes I had to guess a little what you exactly wrote or activated inside CubeMX.
I try to watch it again at home (much better equipment ;) )...
Have a great day!
Marco
‎2019-06-03 3:54 AM
I realize that now. A simple mistake to forget to reduce the resolution - I may have to redo it and also go slower, and with more audio cues, i don't know.
Hope you can manage to make it work, otherwise let me know.
/Martin
‎2019-06-03 6:29 AM
Thanks for the explanation. My application will be very graphics intensive so we will likely be using quite a lot of QUADSPI flash.
Can you explain where this linker script is located in the project structure? I did find an "ioc" file which showed the flashsize that I had setup with CubeMX. This file is a configuration settings file which is not to be modified.
By the way, thanks for the video. It took me a while to find the TouchGFX sub-forum.
I will also suggest that you record in higher resolution because it is very difficult to make out some of the video.
‎2019-06-03 2:19 PM
Martin,
At about 8:30 of the video you add some TouchGFX libraries. You go to project properties > C/C++ General > Paths and Symbols then to the Libraries tab. I cannot read the text that you are adding there (because of the resolution of the video).
Can you elaborate on this or is there a textual based tutorial that would provide additional information that goes along with the video?
‎2019-06-04 4:33 AM
Hi @scottSD​,
First, i'll try to output the video in 1080p and see if that makes a difference. I hadn't noticed that a lower res was the default.
For gcc the linker script is an .ld file:
gcc/STM32F746NGHx_FLASH.ld
‎2019-06-04 4:38 AM
Regarding the library settings (I'm exporting a new video now in 1080p) i'm adding: "touchgfx-float-abi-hard". And for the library path i'm just searching for it inside Middlewares\ST\TouchGFX\touchgfx\lib\core\cortex_m7\gcc\
/Martin
