Generate key pair geneartion
RKOAS
 Am using Nucleo-STM32H573 Board.   i wanted to generate a pair of public and private keys.  Guide me
STea
Hello @RKOAS ,
depending on the asymmetric cryptographic algorithm you can generate a key per via openssl you will find in this lab this method done with STM32wb55 it should be the same for the H5 as well .
you can also generate a key pair with python script  i will provide you with the script in the attached files this script also generates a random message in c format which you can incorporate into you project to test the sign and verification with RSA algorithm .
BR
1 REPLY 1
STea
Hello @RKOAS ,
BR
