Why CAN Bus (J1939) of STM32F405RGT is not working at vehicle's J1939 speed(250kbps) ?
‎2021-03-22 10:31 PM
i am making a J1939 data logger with STM32F405RGT. The vehicle's J1939 is transmitting data on 250kbps, but when i set250kbps in mcu it doesnot show any data on uart terminal , but when i set 500kbps in mcu then it shows some data on UART terminal.
I am using STM32CubeIDE and generated code using CubeMX. The Same firmware that has CAN configured at 250kbps receives data from a CAN Simulator.
CAN
STM32F4 Series
‎2021-03-22 11:58 PM
Are you sure J1939 is compatible with CAN?
‎2021-03-23 12:16 AM
It basically is - J1939 is based on CAN.
> ... but when i set250kbps in mcu it doesnot show any data on uart terminal ,
What is that supposed to mean ?
CAN and UART/RS232 are definitely not compatible.
‎2021-03-23 12:24 AM
I am using UART Only for debugging purpose....
I have configured CAN Receive Interrupt and in Interrupt Handler i am transmitting that data back to UART so that I can see it.
‎2021-03-23 2:14 AM
Any relation between CAN baudrate and UART baudrate seems contrived, and is only caused by your firmware.
Did you check the CAN lines with a scope ?
You should at least have a CAN adapter for your PC, in listen-only mode.
‎2021-03-23 3:30 AM
i have another board than has STM32F446RE ..same firmware work perfectly with the vehicle. getting proper RPM, coolant temperature , cruise control status at 250kbps
‎2021-03-23 7:48 AM
You don't try to run the very same firmware/binary on two substantially different MCUs, do you ?
