Weak SPI clock signal at 12MHz on STM32L4A6ZGT
‎2024-09-09 4:08 AM
Below is the analog waveform for the SPI clock at 12MHz. How to improve the strength of this signal and get p-p 3.3V SPI clock at 12MHz ?
"GPIO SPEED" set to the "VERY HIGH" setting. Apart from this, is there any additional settings required ?
- Labels:
Documentation
SPI
STM32L4 Series
‎2024-09-09 5:31 AM
GPIO speed very high is a good start.
Have you checked that you are using the correct Mode and Alternate Function for that specific SPIn peripheral?
‎2024-09-09 5:36 AM
Yes all that is configured correctly. Communication works fine at lower frequencies. No problems with SPI other than the strength of the clock signal at 12MHz.
‎2024-09-09 8:53 AM
Okay, then check the load next, and remove any loads / connections.
