Warning : Invalid project path: Missing project folder or file: \App1b\B-L475E-IOT01A2 for Source path.
MBour.2
I'm working on a project with a B-L475E-IOT01A2 board and a STM32L475 MCU. I am generating a code using CubeMX and the X-CUBE-BLE-1 software pack and when I build my project, I get this error :
I really don't understand how can a file or a folder be missing when I'm building the project ...
Thanks in advance for your help,
Mohamed
Imen.D
Hi @MBour.2​ ,
I advise you to run the existing projects from the X-CUBE-BLE1 package for the boards supported (as the default example with NUCLEO-L476RG) and compare the project settings with your own using STM32CubeIDE. So, you can check the difference and make corresponding updates in your project.
Imen
Imen
5 REPLIES 5
Imen.D
Hello @MBour.2​ ,
Which IDE are you using ?
Make sure that you have the right include path in the project properties.
Imen
Imen
MBour.2
Hello Imen,
Thanks for your reply, I'm using STM32CubeIDE and regarding the files to include, do you know what we have to include in source location when using a software pack ?
Because every documents are empty...
Mohamed
Imen.D
Hi @MBour.2​ ,
Imen
Imen
Hi Imen,
This is what we eventually did, it works perfectly thank you (once again) !
Mohamed
Imen.D
Hi @MBour.2​ ,
You are welcome :) Glad to know that your issue is solved.
Imen
Imen
