the registry refers to a nonexistent java runtime environment installation or the runtime is corrupted
prs1749
Posted on July 02, 2018 at 07:39
When I try to run STM32CubeMX.exe, The message 'the registry refers to a nonexistent java runtime environment installation or the runtime is corrupted' appears.  I use Windows 7 PRO and Java is up to date.
4 REPLIES 4
Jeff Tenney
Same here.
Yeah several reports in general on the forum. Here on the old forum https://st-microelectronics.jiveon.com/search.jspa?q=%22nonexistent%20java%20runtime%20environment%22
Would recommend using the Java tools to see how many other versions of Java are littering the system and remove any of the old clutter.
Check this thread, and check what the Java Control Panel reports, Mohamed Monsouri would be the ST Employee to seek out.
https://st-microelectronics.jiveon.com/message/201737-not-able-to-run-stm32cubemx-tool
Jeff Tenney
Thank you Clive!
I uninstalled Java, then re-installed it. CubeMX is running for me now.
