2021-06-18 7:01 AM
Hello tinkerer,
i am working with the Stm32Wb55 and trying to send data via Bluetooth, unfortunately when i run or debugg my code, most of the time i lose after 30 seconds the connection because the GATT procedure issues a timeout. In terms of the read property i found a solution with aci_gatt_deny_read() but it only works on read and it does not help me further with write.
I am looking for a solution where i can avoid to get disconnected while my program is running, so i can comprehend my code better. Is there a possibility to avoid the timeout after 30 seconds or have you other ideas to solve the problem.
best regards Alex
2021-08-27 8:15 AM
any news here ?
2024-02-23 4:43 AM
I'm using Bluenrg-M2SA with and facing same with ble connection. Bluenrg-M2SA is connecting with smart watch but GATT procedure issues a timeout at 30 seconds. using BlueNRG-1_2 DK 3.2.3. Any idea to increase the connection time from application?
