STM32L4 ADC partially working
tarzan2
Posted on November 27, 2015 at 17:10
I'm using IAR & cubeMX, and the nucleo board
6 regular channels, no injection :
1/ internal TS
2/ A8 (connected to OPAMP 1) forced at 3.3V
3/ A9 forced at 3.3V
4/ A15 (connected to OPAMP 2) forced at 3.3/2 (voltage divider with 2R)
5/ internal vbat
6/ vref
I'm not concerned about speed. I performed a calibration with HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED);
Internal channels are working, but external channels are not. The ADC returns something between 400 and 700 (@12bits).
I can change the order of measurments, measure only output channel, measure multiple time the same input, in all case, all order, external channel returns floating values between 400 and 700.
I call the ADC conversion fuction every second with : HAL_ADC_Start_DMA(&hadc1, (uint32_t*)temp, 6);
@main() :
  MX_ADC1_Init();
  hadc1.Instance->CFGR = 0x80000000;
@adc.c :
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV2;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
  hadc1.Init.LowPowerAutoWait = ENABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.NbrOfConversion = 6;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  hadc1.Init.OversamplingMode = DISABLE;
  HAL_ADC_Init(&hadc1);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_TEMPSENSOR;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_640CYCLES_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&hadc1, &sConfig);
  sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = 2;
  sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = 3;
  sConfig.Channel = ADC_CHANNEL_15;
  sConfig.Rank = 4;
  sConfig.Channel = ADC_CHANNEL_VBAT;
  sConfig.Rank = 5;
  sConfig.Channel = ADC_CHANNEL_VREFINT;
  sConfig.Rank = 6;
3 REPLIES 3
Chris1
Senior III
Posted on November 30, 2015 at 16:03
What does your GPIO configuration look like?
The L4 devices require a specific mode setting (GPIO_MODE_ANALOG_ADC_CONTROL), e.g.,
    GPIO_InitStruct.Pin = GPIO_PIN_0;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG_ADC_CONTROL;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
tarzan2
Posted on December 01, 2015 at 17:35
Chris T, thank you so much!
- ADC.IN9 was wrongly configured by the STM32L4 FW package v1.0.0. I updated it yesterday for other reasons, and now ADC.IN9 is working.
- Reading your message, I immediately looked at the 2 other inputs. There are configured in opamp.c as GPIO_MODE_ANALOG instead of GPIO_MODE_ANALOG_ADC_CONTROL, even if the opamp output is routed to ADC in cubeMX.
I hope ST will quickly solve this bug because it may be time-consuming :)
With the correction, my ADC now work fine.
Amel NASRI
Posted on December 02, 2015 at 15:45
Hi bonelli,
The reported issue regarding the mode selected for ADC pins should be already fixed in CubeMX 4.11.
Are you using an older version?
-Mayla-
