STM32H745 DAC2 missing
‎2024-12-05 1:00 AM - last edited on ‎2024-12-05 3:02 AM by mƎALLEm
I would need dual DAC using STM32H745. According to datasheet, it should have two DAC converters. In STM32CubeIDE, I can see only DAC1 with two channels. In the datasheet, I can only see DAC1_OUT1 and DAC1_OUT2 pins, but no DAC2 out pins. Is there DAC2 available in STM32H745?
- Labels:
DAC
STM32H7 Series
‎2024-12-05 2:49 AM
Are you asking for F7 or H7? and which H7 part number? they are different!
Please refer to the reference manual DAC implementation section of the correspondent product:
For example STM32G4 has 4 DACs:
This is for STM32H743. It has One DAC with 2 channels.
‎2024-12-05 2:03 AM - edited ‎2024-12-05 2:06 AM
There is only one DAC with two channels on this product in the datasheet:
In CubeMx:
Hope that answers your question.
‎2024-12-05 2:36 AM
I'm a bit confused as everywhere has stated two DAC:
So, there is error in datasheet? Even product selector claims that there are two DACs. Is there any model of STM32H7 family, which actually has dual DAC?
‎2024-12-05 2:41 AM
There is a dac module with 2 channels, out1 and out2 ; these are the outputs of the two DAC.
Just the name is not what you expected.
‎2024-12-05 2:48 AM
So, is it possible the get two independent DAC outputs? I would need two 12bit synchronous analog outputs.
‎2024-12-05 2:49 AM
‎2024-12-05 2:56 AM
I meant STM32H745. There is typo in title.
‎2024-12-05 2:58 AM - edited ‎2024-12-05 3:01 AM
STM32H745 and STM32H743 have the same DAC implementation. So you have one DAC instance with two channels (DAC1_OUT1/DAC1_OUT2).
But indeed there is an issue in the second screenshot DAC2_OUT needs to be DAC1_OUT2 and DAC1_OUT has '1' is missing.
‎2024-12-05 3:59 AM
@mosamasa wrote:So, is it possible the get two independent DAC outputs? I would need two 12bit synchronous analog outputs.
Answered here:
