stm32h7 D1/D0 GPIO
‎2023-08-23 3:25 AM
STM32H7 Series
UART-USART
‎2023-08-25 8:04 AM
‎2023-08-23 3:37 AM
Hello @wjian.2 :
Could you please provide more details, which STM32 product you are using?
‎2023-08-23 3:55 AM - edited ‎2023-08-23 3:59 AM
‎2023-08-23 9:39 AM
Repeatedly reposting basically the same topic to multiple threads is not helpful, pick one and stick with it.
‎2023-08-23 12:53 PM
I have a Nucleo-H723ZG where I was using a CAN transceiver on the Zio connector. After failure to get the CAN bus communcation working. I started to troubleshoot and I found that the schematic did not label the CAN RX/TX correctly. It was off by one pin.
If it's possible, you might want to ohm out the D1 which I assume is on the Arduino connector to the uC pin to see if there is a direct connection?
TimerCallback tutorial! | UART and DMA Idle tutorial!
‎2023-08-25 8:04 AM
