STM32H5 ECC errors and ICACHE invalidation
PieterG
Should ICACHE be invalidated when a double ECC error occurs?
Sarra.S
Hello @PieterG, sorry for the delayed answer,
When two ECC errors occur during a read, the flash interface sets the double error detection flag ECCD in the FLASH_ECCDETR register
and when this flag is raised, an NMI is generated, and the software must invalidate the instruction cache (CACHEINV = 1) in the NMI interrupt service routine when the ECCD flag is set.
I hope that answers your question!
6 REPLIES 6
Sarra.S
Hello @PieterG
Please check: How to avoid a hard fault when ICACHE is enabled on the STM32H5 series
Maybe I've overlooked it, but I have read the article several times and it does not mention how ECC errors are to be handled?
I am quite sure that I read about invalidating ICACHE after a double ECC error, but I cannot find it anymore in the official documentation, nor any of the examples.
Does it make any sense to invalidate ICACHE when a double ECC error occurs in FLASH? Or is there no need for that?
@Sarra.S
Can you please point me to where this knowledge base item explains whether ICACHE should be invalidated on double ECC errors?
Or alternatively a simple yes or no answer would also be very helpful.
Sarra.S
Thank you @Sarra.S for your answer.
I guess invalidating the ICACHE is only necessary when ICACHE is enabled for the flash sector in which the error occurred? (in other words, I do not have to invalidate ICACHE for double ECC errors in OTP / EDATA for which I disabled caching in the MPU)
Yes!
