STM32G491 datasheet echo!
The sentence "Exposure to maximum rating conditions for extended periods may affect device reliability" is repeated:
2 REPLIES 2
STTwo-32
Hello @Andrew Neil
Thank you so much for reporting this typo. I've report it to the concerned team for correction on the coming releases (under internal ticket number 192316).
Best Regards.
STTwo-32
Karl Yamashita
Lead III
ST is making sure you didn't miss reading it the first time and it sticks to your memory
Don't worry, I won't byte.
TimerCallback tutorial! | UART and DMA Idle tutorial!
