Stm32G431KBU6 CANFD can't work when BRS On?
2024-04-11 7:53 PM - last edited on 2024-04-12 12:39 AM by mƎALLEm
Hi community:
I'm using CANFD on stm32g431kbu6 board, but I find some issue that CANFD cant work normally with BRS ON,my config of CANFD show in the comments。Does anyone know about this?
FDCAN
STM32G4 Series
2024-05-07 4:31 AM
You need to increase TSEG1 and TSEG2 as much as possible an decrease the prescaler either for Nominal or data phases.
TSEG1 ~= 80% (TSEG1+TSEG2) for sampling point at 80%
2024-05-07 4:50 AM
Because my slave CANFD device is working in sampling point at 75% of data phase, data baud is 5MHz, so I want to set at 75%, it seems work good now, I'll conduct pressure testing for a period of time.If this kind issues happen again, I'll try your advice.
2024-05-07 4:57 AM
75% or 80% doesn't make much difference.
- « Previous
- 1
- 2
- Next »
