2020-10-04 10:47 PM
This errata is difficult to understand as written.
Can you provide diagrams for Section 2.7.4?
Can you confirm that if I use continue mode there aren't any problems?
Help.
2020-10-05 7:08 AM
Please find the attached document as requested.
In case of continuous mode: if regular conversions are in continuous mode and injected conversion occur then there is the same problem:
interruption of regular conversion by injected.
2020-10-05 7:08 AM
2020-10-05 6:08 PM
Thank you for the incredibly quick response.
It looks like if there is no abort by the injected channel, this errata doesn't apply?
