STM32G030K6T6 with PWM
2023-04-24 9:18 AM
I'm trying to configure the PWm with STM32G030K6T6. But pwm is not generate.
below I given my code and i don't know where i made a mistake if any one know help me.
RCC->IOPENR |= (RCC_IOPENR_GPIOAEN); // I/O port A clock enable
GPIOA->MODER &= ~(GPIO_MODER_MODE8); // clear 8th pin
GPIOA->MODER |= (GPIO_MODER_MODE8_1); // 10: Alternate function mode
/********** TIMER 1 Init **********/
RCC->APBENR2 |= RCC_APBENR2_TIM1EN; // TIM1 CLOCK ENABLE
TIM1->CR1 &= ~TIM_CR1_DIR; //Set Counter Direction as Up-Counter
TIM1->ARR = 1; //ARR VALUE IS 0-65535
TIM1->PSC = 2000-1; //PERSCALER VALUE IS 0-65535
TIM1->CCR1 = 1000; //Duty Cycle
TIM1->CNT = 0; //COUNT START IN 0
TIM1->RCR = 0;
TIM1->CCMR1 |= 0x00000068; //Configure the pins as PWM
TIM1->EGR = TIM_EGR_UG; // Update generation
TIM1->CCER |= TIM_CCER_CC1E; //Capture/Compare 1 output enable
TIM1->BDTR |= (TIM_BDTR_OSSR | TIM_BDTR_MOE); // Off-state selection for Run mode & Main output enable
TIM1->CR1 |= (TIM_CR1_CMS_0 | TIM_CR1_CEN); // COUNTER ENABLE & Center-aligned mode selection (01: Center-aligned mode 1)
- Labels:
STM32G0 Series
TIM
2023-04-25 2:54 AM
TIM1_CH1 is AF1 for PA8, so you need to set GPIOA_AFR[1] accordingly.
Generally, if in doubts, read out and check/post content of TIM and relevant GPIO registers.
2023-04-24 9:38 AM
Hello @Sudhakar.R,
it might be helpful to provide more information about your hardware setup and any error messages or behavior you are seeing
2023-04-24 10:26 AM
Hi @Sarra.S
I'm using ST - link v2 for debugging and logic analyzer for checking pulse with stm32g030k6t6. And I'm not getting any error message.
2023-04-24 11:59 AM
With this setting, TIMx_CNT counts from 0 to 1 and then back to 0. It never reaches TIMx_CCR1 so compare never happens, thus there's no edge on the output signal, exactly as you've observed.
Set TIMx_ARR to a value higher than TIMx_CCR1.
2023-04-24 12:22 PM
You've probably swap PSC and ARR values...
2023-04-24 10:08 PM
I changed PSC = 1 and ARR = 2000 still pwm is not generate.
2023-04-25 2:54 AM
2023-04-25 10:32 PM
@Community member
Thank you for reply. i got the output.
