stm32f722ze SDIO connection Problem .SD card not detected. CD is ignored and not connected
‎2023-05-23 10:19 PM
trying to connect sd card with stm32f722ze SDIO 4 bit method . but still i couldn't succeed in sd card detection . sd card socket CD pin i ignored and not connected with any pin . I need to know CD-card detection is important ? . and which repository examples having sdio 4 bit example?
- Labels:
SDIO-SDMMC
STM32F7 Series
‎2023-05-24 12:00 AM
Oops ! Single bit connection is working . let me change change sd card socket and come back to you on 4 bit mode .
‎2023-05-24 12:18 AM
Hi @MMARI.1​ ,
Is your project generated with STM32CubeMX?
If yes, could you please check that the workaround provided in this thread: SDCARD does not work (FR_NOT_READY) when migrating from FW_F4 V1.27.0 to newer FW_F4 V1.27.1.
Kaouthar
‎2023-05-24 9:09 AM
currently 1(singel) bit SDIO working & 4bit sdio not working .
i am using cube ide and i have changed the SD card socket .
On stm32f7xx_hal_sd.c i have modified code from Init.BusWide = SDMMC_BUS_WIDE_1B; to Init.BusWide = SDMMC_BUS_WIDE_4B; still 4bit sdio is not working . Any one please check with Nucleo - f722ze with sdio 4 bit at your technical Centre and update me where i need to modify the code . i think this problem occurrence due to recent firm ware migration .
‎2023-05-24 9:20 AM
Review the schematic, check for and remove stubs.
33 or 47K pull-ups on the Dx and CMD wires?
Dial back the slew speed, significantly.
‎2023-05-24 7:13 PM
Madhavan
‎2023-05-25 9:13 AM
can any one share with me the old firmware !!!!!! stm32f7xx_hal_sd.c !!!!!!!!!! file then i can understand where exactly i need to modify the code !. or working file of 4bit SDIO stm32f7xx_hal_sd.c file
