2024-03-11 6:06 PM - last edited on 2024-06-10 3:30 AM by mƎALLEm
Hi
I'm trying to read a 2.5V signal through internal adc as soon as I connect the signal to the gpio pin of stm there is shift(to positive side)in the signal and also generating the noise upon seeing through oscilloscope.
Also made ground connection.
2024-03-11 6:18 PM
What pin on what board?
Check the schematic to understand what might be on the pin
Perhaps use a opamp so as not to load the signal.
2024-03-11 7:55 PM
Pin PA4
Using voltage divider to lower the voltage from 46V to 2.5V and giving the signal to Stm.
