STM32F407VGTX_FLASH.ld: No such file or directory error
‎2023-03-15 1:20 AM
Hi i wanted to try new extension but i get this error. The code is a basic blink its working on cubeide but when i try on vscode this happens.
Thank you already
[build] c:\st\stm32cubeide_1.10.1\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.10.3-2021.10.win32_1.0.0.202111181127\tools\arm-none-eabi\bin\ld.exe: cannot open linker script file C:/newcodes/ledblink/STM32F407VGTX_FLASH.ld: No such file or directory
[build] collect2.exe: error: ld returned 1 exit status
STM32F4 Series
‎2023-03-15 1:46 AM
Hi @Hüseyin Avni Sarıkaya​
Did you check that the path is valid? Or, if the file is missing, you can try to copy it from the original project.
‎2023-03-15 1:52 AM
Yeah path is valid and file is missing but i didnt try copiying it is linker files project spesific or its global for that mcu?
‎2023-03-16 7:24 AM
could you try a shorter path please without special characters
‎2023-03-23 4:32 PM
If the linker file is missing how is this building in STM32IDE? Did you import this project using the STM32 extension in VSCode?
