2024-04-11 04:06 AM
I am a little confused here, AN392 claims to run STM32C0 from a 5V power supply, directly from the main fed RCD dropper with a 5.6V Zener. But the datasheet says the maximum voltage is 4V.
So does the AN suggest running way over max specs or is there something I miss?
2024-04-11 04:09 AM
Good catch. Need to check this internally.
2024-04-11 04:10 AM
You mean this?
2024-04-11 04:45 AM - edited 2024-04-11 04:45 AM
Internal ticket 178788 has been created to fix this. The ticket is not accessible by the community users.
