2024-08-05 05:21 AM
I had to calculate the sine wave signal in function generator voltage and the adc value I had implemented while changing frequency the voltage and adc values are constant I had stucked in this
2024-08-06 01:47 AM
Hello @vijay79444,
Could you share your ADC configuration (reference voltage and input channel settings) and further detail the issue?
1st general hint: the ADC's sampling rate must be at least twice the highest frequency of the sine wave
2024-08-06 01:47 AM
Hello @vijay79444,
2024-08-06 02:49 AM
You need to give more details - see the posting tips:
@vijay79444 wrote:I had to calculate the sine wave signal
What do you mean by "calculate" here ?
@vijay79444 wrote:the adc value I had implemented while changing frequency the voltage
Pardon ??
