Sin wave measuring using adc stm32g474re nucleo
vijay79444
I had to calculate the sine wave signal in function generator voltage and the adc value I had implemented while changing frequency the voltage and adc values are constant I had stucked in this
Sarra.S
Hello @vijay79444
Could you share your ADC configuration (reference voltage and input channel settings) and further detail the issue?
1st general hint: the ADC's sampling rate must be at least twice the highest frequency of the sine wave
Andrew Neil
Evangelist III
You need to give more details - see the posting tips:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
What do you mean by "calculate" here ?
Pardon ??
