SD Card SDIO not working(FR_DISK_ERR)
‎2024-01-18 5:44 AM - last edited on ‎2024-01-22 6:23 AM by Peter BENSCH
I have a custom board and I have to run an SD card on it using SDIO protocol however on f_mount() function it takes a long time to come out with error FR_DISK_ERR but when I call "HAL_SD_GetCardInfo(&hsd, &sdCardSpace)" then I am getting all the data. I have tried with both 1-bit and 4-bit SDIO and DMA but none is working. I need help to figure out if its hardware error or software error or what the error is.
SDIO-SDMMC
‎2024-01-29 8:43 AM
Hello @fs and welcome to the Community :),
Could you please precise, which STM32 device are you using?
Do you use the STM32CubeMX for code generation?
Thank you.
Kaouthar
‎2024-01-29 8:48 AM
Also, try to check the SDcard on another device PC/laptop or others .. It could be an issue on the SDcard you are using!
