PWM No Output for TIM1 on STM32L476
‎2024-03-21 5:00 AM - edited ‎2024-03-21 6:56 AM
I use Cube to setup TIM1_CH4 on PE14 as PWM
Setup of ioc
PE14 -> TIM1_CH4 in pinout
TIM1:
Ch 4 PWM Generation Ch4
Conter Settings: Counter period 20
PQM Generation Cannel 4: Pulse 5
Modification of main:
/* USER CODE BEGIN 2 */
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_4);
It should be this simple, but no output on PE14...
(I tested PE14 as GPIO so its not wrong pin I look at...)
STM32CubeMX
STM32L4 Series
TIM
‎2024-03-21 8:01 AM
I actually got it to work at 4 MHz now, but not 8 MHz as was my goal.
Conter Period should be 9 and pulse should be 5 I guess. That worked for TIM2 but not for TIM1... It is too advanced to be fast?!?
‎2024-03-21 5:45 AM
I don't use Cube but TIM1 is an Advanced Timer and needs TIMx_BDTR.MOE to be set.
‎2024-03-21 6:20 AM
Hello @peter,
This should work with HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_4); your config/ code looks correct
I see you're using a custom board, have you tried to output another signal on those pins?
‎2024-03-21 7:10 AM
Just to verify that PE14 is operational i once more (typo PE15 in original post) verified my setup for measurement, and it seems fine.
As far as I understand the MOE is set with the PWM project.
‎2024-03-21 7:16 AM
Show all Timer and relevant GPIO registers content.
‎2024-03-21 7:34 AM
@PeterL , you set timer to 80/20 -> 4MHz output, with 5 ticks pwm, 60ns pulse.
But set pin to low speed, -> set high.
And set debug not to disable, if you want to debug.
try mod. ioc:
‎2024-03-21 8:01 AM
‎2024-03-21 8:18 AM - edited ‎2024-03-21 8:23 AM
So set period (arr) to 9 , not 20. (80 / (9+1) = 8 MHz )
