OS install error
‎2021-05-21 7:09 AM
I just got a stm32L475 Iot Kit.
And after compilation, I got this error .
st-flash 1.7.0-23-ga9adf9c
2021-05-21T22:17:24 INFO common.c: L4xx: 96 KiB SRAM, 1024 KiB flash in at least 2 KiB pages.
open(./BUILD/DISCO_L475VG_IOT01A/GCC_ARM/thingsboard-l475vg-iot01a.bin) == -1
2021-05-21T22:17:24 ERROR common.c: map_file() == -1
stlink_fwrite_flash() == -1
I don't know what this means.
Please tell me what I did wrong.
Thank you
STM32L4 Series
‎2021-05-31 11:15 PM
Thank you for your answer of my question.
But never mind it, I already make it.
I compiled them on mbed online compiler on windows 10 and I copied a .bin file to my board.
It worked very goo.
Thank you anyway.
Kwansoo
‎2021-05-31 9:18 AM
Hi @KYang.7​ ,
- which example are you trying to compile?
- what are you using as compiler?
-Amel
It worked very goo.
Thank you anyway.
Kwansoo
‎2021-06-01 3:24 AM
Glad to know that all is working fine for you, @KYang.7​ .
-Amel
