2019-01-24 03:12 AM
I tried to plug a shield arduino RS485 shield that fits on NUCLO-F401RE without any chance because of wrong spacing
2019-01-24 03:52 AM
those pins are spaced I believe 2.5 mm which is standard for the connectors. Use jumper connectors. for example the arduino mcufriend tft display plugs in without problem. which is very nice combo. Except the fact I couldn't not find any libraries to light it up.
2019-01-24 03:52 AM
Are you sure you tried to plug it in the right connectors with the right orientation? We already used arduino shield on the NUCLEO-F767ZI with no problem.
