Low power modes on STM32L4 series MCU
Vvenk.1
Below is my requirement:
  1. Need to send a DAC sample every 2ms (on 32KHZ clock)
  2. Every 12 sec will do an access to external flash to copy a block of memory (on HSI clock)
how can i accomplish this? am new to microcontroller, can anyone help me with some link/ tutorial on this.
Venkatesh
KnarfB
Principal III
A tiny example using a timer driven DMA triggering DAC is this: https://m0agx.eu/2019/03/30/generating-signals-with-stm32l4-timer-dma-and-dac/
This works also in sleep mode where the MCU core is halted except for interrupt handling.
The block copy from flash could be done in the circular DMA (half-)completion handlers.
Imen.D
Hello @Vvenk.1​ ,
You can get inspired from the DAC example for your board within STM32CubeL4 package and refer to the STM32L4-DAC training and
AN3126 Application note Audio and waveform generation using the DAC in STM32 products
Hope this helps you.
Imen
Imen
