2021-05-11 09:09 AM
I would like to make communicating power converters that I can program with Simulink. I use several NUCLEO G474RE and when I configure them with CubeMX I can enable FDCANs but not CANs. The problem is that in the Simulink library there are CANs blocks and not FDCANs, hence I can't find how to link my Simulink blocks to the FDCAN I enabled.
Does anyone know a way to bypass this problem?
Thanks in advance.
2021-05-11 01:50 PM
No CAN-FD is not supported only CAN is supported
2021-05-11 01:50 PM
2021-05-17 03:19 AM
Oh too bad, thanks for your answer though.
