Is it possible to disable SBK (break frame) on STM32G474RB on Asynchronous mode UART?
RPG
Senior
I have been looking in the documentation and break frame gets mentioned but cannot find whether is possible to disable the SBK.
Andrew Neil
Evangelist III
Didn't we cover this in your other thread?
https://community.st.com/s/question/0D53W00001eaoyCSAQ/after-uart-send-the-bytes-from-the-buffer-0-is-also-received
It was a red herring - nothing you need to worry about.
The UART won't generate a Break unless you specifically force it to.
2 REPLIES 2
Andrew Neil
Evangelist III
RPG
Senior
Yes I created this before the other issue got solved. It can be actually deleted. Thanks for the help. I have learnt a lot :)
