Is it possible to disable SBK (break frame) on STM32G474RB on Asynchronous mode UART?
RPG
I have been looking in the documentation and break frame gets mentioned but cannot find whether is possible to disable the SBK.
Didn't we cover this in your other thread?
https://community.st.com/s/question/0D53W00001eaoyCSAQ/after-uart-send-the-bytes-from-the-buffer-0-is-also-received
It was a red herring - nothing you need to worry about.
The UART won't generate a Break unless you specifically force it to.
RPG
Yes I created this before the other issue got solved. It can be actually deleted. Thanks for the help. I have learnt a lot :)
