I2C Problem
‎2023-07-03 3:33 AM
I have 2 MCU, one is the STM32F401RE acting as master and the other is STM32G474RE acting as slave, I have kept both the controllers in open drain and pulled up, the slave address is 0x30<<1, I think the data is being transferred because on pressing the reset button on the master, the slave displays this over UART "SLAVE HAL I2C NOT READY" , live expression is not working for me so that was my other option.
My master code is this
I2C
STM32F4 Series
STM32G4 Series
‎2023-07-03 6:28 AM
Hello @Epsilon03,
I quickly looked at your code, here is a list of suggestions/questions for you:
- What displays the master over UART ? Run your Master.c in debug mode to verify the address is well acknowledge and to check the transmission.
- What is the value of aRxBuffer once the code ended ? You can also display it via UART.
- Are you using OpenOCD ? It does not support Live expressions. You need to switch the debug probe to either ST-Link GDB server or J-Link, they both support the feature.
- It might also be a synchronization issue, try to add a little delay to make sure the master transmits once the slave is ready.
Best Regards,
Pierre
‎2023-07-03 6:44 AM
‎2023-07-03 9:56 PM - edited ‎2023-07-03 10:31 PM
@Pierre_Paris @TDK, I got the live expression working, basically for some reason it was disabled and now I have set it to the highest level of debugging, I also realized that the code is working, once the live expressions allowed me to see what is inside the slave receiving variable.
Also @TDK the "Slave HAL I2C NOT Ready" is only printing on resetting my master board or the slave board.
However there is one issue still remaining, I cannot display the data I received on my slave device, on UART. It's not exiting loop, probably due to the non-blocking feature like TDK mentioned, how do I get around that?
Edit: The data I was sending was bigger than the rxBuffer so the program was waiting for the complete data to be transferred, on shortening the data, UART started displaying the Data .
Thanks for all the help!! @TDK @Pierre_Paris.
‎2023-07-05 8:37 AM
Hello @Epsilon03,
The problem must be with I2C and not the UART. I think you aren't exiting the loop because you're sending aTxBuffer with a size of 150 uint8_t but you declare aRxBuffer with a size of 100. The master wait an acknowledge from slave and don't go back in the ready state. The master never terminates the transmission with a STOP condition.
Can you please fix it and tell me if it still gets stuck ?
Best Regards,
Pierre
