I ran printf over UART but the results were not displayed in Tera Term
t-oka
Hello everyone
I'm using stm32f207ztg6 and want to do printf using UART, but it doesn't show up in Tera Term.
How can I solve this problem?
■ Program used
// *-*-*↓main()-*-*-*-*-*-*-*-*-*-*-*-*
setbuf(stdout, NULL);
while (1)
/* USER CODE END WHILE */
printf("Hello World\r\n");
HAL_Delay(1000);
/* USER CODE BEGIN 3 */
int _write(int file, char *ptr, int len)
HAL_UART_Transmit(&huart2,(uint8_t *)ptr,len,10);
return len;
static void MX_USART2_UART_Init(void)
/* USER CODE BEGIN USART2_Init 0 */ /* USER CODE END USART2_Init 0 */ /* USER CODE BEGIN USART2_Init 1 */ /* USER CODE END USART2_Init 1 */ huart2.Instance = USART2; huart2.Init.BaudRate = 115200; huart2.Init.WordLength = UART_W ORDLENGTH_8B; huart2.Init.StopBits = UART_STOPBITS_1; huart2.Init.Parity = UART_PARITY_NONE; huart2.Init.Mode = UART_MODE_TX_RX; huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart2.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART2_Init 2 */
/* USER CODE END USART2_Init 2 */
■STLink: STLink Virtual COM Port
■Situation
When HAL_UART_Transmit is executed, HAL_OK is returned, but nothing is displayed in "Tera Term".
Hello @t-oka ,
First, before starting the printf usage over UART, you need to validate the UART transmission by for example just sending a couple of characters using HAL_UART_Transmit().
Second, you need always to check the schematics or board's user manual before suspecting an issue in the FW.
According to the schematics of MB1137 the UART instance connected to STLink-VCP on NUCLEO-F207ZG (MB1137) is USART3 and not USART2:
So you need to select USART3 instead of USART2
Refer to this printf example. on NUCLEO-F207
Hope it helps.
6 REPLIES 6
SofLit
You didn’t tell which board you are using?
Hello!
I am using a Nucleo board.
Which Nucleo board?
Please see the posting tips - including how to properly post source code:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Before adding the complications of printf, have you got this working by just doing the HAL_UART_Transmit direct?
If that doesn't work then, clearly, printf is never going to work!
Also note that stdout is line-buffered - ie, the output won't appear until you send a newline...
PS:
https://community.st.com/t5/stm32cubeide-mcus/retarget-printf-on-stm32g070rbxx-cortex-m0/m-p/721066/highlight/true#M30729
Hello @t-oka ,
Hope it helps.
I was able to solve the problem with the help of your schematic and example.
Thanks.
>You should always check the schematic or the board's user manual before suspecting a FW problem.
→You're right...
Also, see the tips in your posting - how to properly post source code, etc:
I'll be careful about that too.
That's probably the key difference between embedded C (particularly on small microcontrollers), and C on "big" systems (Linux, Windows, et al) - you need to understand the hardware context.
See also:
https://community.st.com/t5/stm32-mcus-embedded-software/ds18b20-sensor-detection-via-one-wire-1-wire-protocol/m-p/729960/highlight/true#M55863
#HardwareMatters #EssenceOfEmbedded
