AVerm.4
Retarget printf on STM32G070RBxx Cortex M0+
I'm trying retarget printf. My uart_write function is working correctly and i'm able to see character on Teraterm.
But when i try to use printf it is not working. i even tried semihosting to execute printf but it fails. i'm attaching the screenshots -
any solution for this problem?
    Andrew Neil
    Andrew NeilBest answer
    Just noticed that you are doing this in C++
    The linked articles are both just C, and I have just used C.
    Could you try this in a plain C project to see if that makes a difference?
    EDIT:
    See: https://community.st.com/t5/stm32cubeide-mcus/stm32cubeide-c-redirected-printf-no-longer-works-how-to-use-cout/m-p/285002/highlight/true#M14943
    KDJEM.1
    Hello @AVerm.4 ,
    I recommend you to refer to this FAQ: How to redirect the printf function to a UART for debug messages and follow the steps.
    This article describes how to redirect the printf output to the STM32 UART peripheral that is connected to the UART pins on the embedded ST-Link that will be transmitted to the host computer and displayed via a windows terminal program, Tera Term using Nucleo-G070RB.
    I hope this help you!
    Thank you.
    Kaouthar
    AVerm.4
    AVerm.4Author
    Hi @KDJEM.1 ,
    I appreciate your comment. But the link provides the way to retarget HAL library UART, which i see is working fine.
    But here I'm using CMSIS library to write my UART driver. And here it is not working.
    Andrew Neil
    It really shouldn't make any difference - they all just end up writing to the UART.
    If you're hitting a BKPT instruction, that suggests you're configured for semihosting - you don't want that.
    Andrew Neil
    Please see this for how to capture a screenshot - far better than photographing the screen!
    https://www.techrepublic.com/article/how-to-take-screenshots-in-windows-10/
    For posting source code, please see the posting tips:
    https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
    AVerm.4
    AVerm.4Author
    @Andrew Neil sorry for that. I'm not using a personal computer rather a corporate one were we have limited access to file sharing.!
    Andrew Neil
    Presumably, the screenshots you shared show your semihosting attempt - as this works via the BKPT instruction?
    https://interrupt.memfault.com/blog/arm-semihosting
    Instead, follow the Knowledge Base article linked by @KDJEM.1
    And here's a 3rd-party article on the same: https://shawnhymel.com/1873/
    Andrew Neil
    EDIT:
    AVerm.4
    AVerm.4Author
    Tried with the C project as well it's not working.
    It printed few lines then threw some garbage. I retried debugging but now nothing displayed on terminal.
    Do I need to increase baud rate from 9600 to 115200? Because it's taking time to print.
    Andrew Neil
    As noted, that's expected behaviour for stdout (used implicitly by printf)
    From the other threads, you should be able to disable the buffering with:
    setbuf( stdout, NULL );
    https://en.cppreference.com/w/c/io/setbuf
    Or use stderr
    Or just send a newline.
    KDJEM.1
    Hello @Andrew Neil ,
    Thank you for this proposal. I reported this request internally.
    Your feedback and request are welcome.
    Thank you.
    Kaouthar
    Andrew Neil
