I'm using the stm32f0 series. I have it right now, so I'm doing it with a signal generator. I want to count every rising edge of the signal my code is as below but it is not counting prope
hdemi.1
5 REPLIES 5
gbm
Lead III
Use the measured signal input as timer clock input. You cannot use capture function reasonably at 10 MHz.
How fast is the STM32 clocking?
Not counting properly? Please expand on what it is doing..
Should be using External Clock modes, probably not measuring cycles.
> TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV2;
Why? (although I don't think this makes any difference in this particular case)
> TIM1->SMCR |= TIM_SMCR_SMS_2 | TIM_SMCR_SMS_1| TIM_SMCR_TS_2 | TIM_SMCR_TS_1;
That's TIM1_SMCR.SMS = 0b110 = Trigger Mode.
You probably want 0b111 = External Clock Mode 1, don't you.
Plus all the questions of TeslaDelorean.
hdemi.1
I don't quite understand what you mean, can you give an example?
I expect it to count every time a rising edge in but it doesn't
