STM32H750XBH6 HSE Crystal
BHell.1
Hello
Challange to find a 25MHz HSE crystal due to extended lead times.
Please let me know if this quartz crystal will work?
ABM11-25.000MHZ-D2X-T3
20PPM
From my point of view I think it will work.
Please have a look and confirm. Thank you for your help!
https://abracon.com/Resonators/ABM11.pdf
The STM32 can use a broad range of crystals and frequencies, you'd need to run the math and determine the suitable capacitors, and perhaps resistors. Perhaps work with your FAE to establish a number of suitable crystals.
https://www.st.com/resource/en/application_note/cd00221665-oscillator-design-guide-for-stm8afals-stm32-mcus-and-mpus-stmicroelectronics.pdf
What's the application? That's going to drive the performance requirements of the crystal.
Radio, Ethernet, CAN and USB have expectations.
BHell.1
Hello Tesla
Thanks, yes I have USB but no Ethernet or CAN.
I have done the math and my conclusion is that the CL needs to be below or equal to 10pF, should be 6-8 for a better margin since the trance will add xpF. Problem is still the stock.
