How to receiving variable length string via uart (stm32f407ve) ?
Aabc
4 REPLIES 4
Guru
You can use HAL_UARTEx_ReceiveToIdle which will return when the line becomes idle or the specified number of characters are received.
S.Ma
Principal
Or the 8 bit mcu way, interrupt from each incoming byte, when 0 or /n termination char is detected, flag the message for task to process it, and continue receiving in another income buffer.
Piranha
Chief II
Aabc
Thanks for all you
