How to handle Variable length receive data via UART?
‎2021-12-01 9:18 AM
uint8_t rx_buffer[32], rx_flag, rx_index, rx_data, RxData[32];
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
if (huart->Instance==USART1)
//if the data is not being received, clear the buffer
if(rx_index ==0)
for (int i=0; i<20; i++)
rx_buffer[i]=0;
//if the character received is other than 'enter' ASCII13, save the data in buffer
if(rx_data!=13)
rx_buffer[rx_index++]=rx_data;
else
rx_index=0;
rx_flag=1; // turn the rx_flag 'ON'
HAL_UART_Transmit(&huart1, rx_buffer, sizeof(rx_buffer), 100); // transmit the data via UART
HAL_UART_Receive_IT(&huart1, &rx_data, 1); // restart the interrupt reception mode & receive only 1 char at a time!
I declared a 32byte rx_buffer[], when I send more than 32 Bytes, the board couldn't receive any more serial data through interrupts! Attached my sample callback function and code inside that portion!
Thangz
Interrupt
STM32L1 Series
UART-USART
‎2021-12-02 9:54 AM
stm32l1xx_hal_msp_template.c file is not expected to be compiled. Maybe you added it the the list of objects in your projects ?
However, if you are using CubeMx, the generated stm32l1xx_hal_msp.c file should contain a valid HAL_MspInit() body (for example all peripheral clocks are to be enabled here). Without this function body, it can't work.
Could you use the previous content of HAL_MspInit() function when you were able to receive some chars ?
‎2024-08-27 11:51 PM
@Guenael Cadier , @TMuka.1 , @TDK
I find the solution the Guenael Cadier suggested (UART DMA circular buffer ReceptionToIdle) exactly what I am leaning to with my application (variable length commands) and I will be moving now towards the implementation.
I cannot see in the Examples\UART\ folder the UART_ReceptionToIdle_CircularDMA example for STM32L05x (CubeIDE 1.12.1)
Actually there is no implementation of HAL_UARTEx_ReceiveToIdle_DMA for STM32L0 family in stm32l0xx_hal_uart.
Can you please indicate where I could find/download examples? Or does L0 family not support this function?
‎2024-08-28 12:09 AM
Hi @_alaBaster
I think ReceiveToIdle API should be available in latest STM32L0 HAL drivers version (please check in stm32l0xx_uart_ex.c). If not, maybe you could have a look in latest version of STM32L0 HAL drivers available on github here .
API prototypes are present in stm32l0xx_hal_driver/Src/stm32l0xx_hal_uart_ex.c
‎2024-08-28 7:02 AM
There aren't any examples in the L0, but you can adapt the examples for another family.
The function definition is here:
‎2024-08-29 3:04 AM
Hi @Guenael Cadier got it, thanks. I was looking only at stm32l0xx_hal_uart.c
Kind regards
‎2024-08-29 3:05 AM
ok great, thanks. Now it is time to dive into it! :)
- « Previous
- 1
- 2
- Next »
