Hi, it's possible to use an external clock of 8Mhz (HSE generated by a crystal) on STM32G0B1KBT6 (LQFP32 pinout) on PC14 or PC15?
‎2022-12-22 3:18 AM
‎2022-12-23 2:26 AM
Hi @MPenz.1​,
You can use an External High Speed clock mapped on OSC_IN with HSE in bypass mode.
But not a crystal resonator because which would require OSC_OUT pad to maintain the resonator effect. And the OSC_OUT isn't available with LQFP32 package.
Thank you.
Kaouthar
‎2022-12-22 6:35 AM
Hello @MPenz.1​ and welcome to the Community :),
If you refer to this STM32G0B1 datasheet, and precisely table 12, you can conclude that the PC14-OSC32_IN support the OSC_IN and OSC32_IN for LQFP32 package.
For that, you can use the HSE or LSE on PC14.
Thank you.
Kaouthar
‎2022-12-22 6:40 AM
Thanks for the reply. I want to use HSE therefore I need OSC_IN and OSC_OUT. Where I can find OSC_OUT on the LQFP32 package?
‎2022-12-23 2:26 AM
Hi @MPenz.1​,
Thank you.
Kaouthar
‎2022-12-29 9:47 AM
Other STM32 32-pin devices host CK_IN / OSC_IN on the PA0 pad. Also 20 and 28-pin variants (see L011 for example)
Is this different here, or an oversight in the bond-out ? Rather disappointing..
