Hard Fault with Floating point and DSP
luke514
I am using STM32F302R8
I have a long code that triggers the Hard Fault interrupt after a few seconds because of these instructions (of the sine in particular):
The theta_fi angle is TIM6->CNT and I need to convert it from q15 to floating point.
I tried with both arm_q15_to_float function of DSP ... and arm_q15_to_float_new found online.
I can't figure out what the problem is.
5 REPLIES 5
Perhaps start by looking at what's actually Faulting, what the MCU reports as it's objection, and the registers and code at the site of the fault?
I can't figure it out because with breakpoints the code works .. while it stops working after a few seconds when debugging without breakpoints so I can't trace back as much informations
I've never had an error like this happen to me so I'm not sure what to do
Instrument your code so you know what's happening.
A while(1) loops going to tell you, and support staff on a phone, nothing.
https://github.com/cturvey/RandomNinjaChef/blob/main/KeilHardFault.c
Tend to be gross failures:
Corrupt pointers or stack
Over-run local/auto variable space on the stack
Misaligned pointers
FPU not enabled
Interrupts / register corruption
STOne-32
Hi @luke514 ,
try to change the compiler optimization level from best for debug and best for speed or size and see if you observe the behavior change or occurrence of the timings , this will change the generated assembly sequences and code alignment. Let us know .
Ciao
STOne-32
The error appears the same with all types of optimizations, I just tried.
