H573 - problem to install freertos with CubeMX
Artomatica
When I try to use X-CUBE-FREERTOS on H573 board, there is a warning sign and it is impossible to install.
How do I install X-CUBE-FREERTOS bundle for CubeMX?
Thanks!
Imen.D
Hello @Artomatica and welcome to the Community 🙂
You should first install the X-Cube-FREERTOS package from: Help > Manage embedded software packages > STMicroelectronics.
Imen
Imen
Imen.D
Imen
Imen
Artomatica
Thanks, login into the account fixed the problem.
