GPIO CONFIGURATION IN TRISTATE mode
shall we able to configure stm32g431mb gpio to high impedence state when configured as output pin. We need to access output pin in tristate mode
4 REPLIES 4
Danish1
Lead III
Look at the Reference Manual for your stm32.
This will tell you how bits in the appropriate GPIOx->MODER control whether a pin is output or input.
When you want to go from output to tri-state (digital input) you can reprogram those bits.
There probably is a HAL way to do this, but I don't find it adequately documented.
Of course. Set output type to mode "open drain" and write "high" to pin. Then it will be output in HiZ.
What do you mean by that? What "access" ?
Jacob WOODRUFF
Hi All,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Regards,
Jake
ST Support
