DMA transfers using double buffers from external SRAM devices
forst
Hello
​I am considering a double buffer DMA transfer using FMC
I want to DMA the data from the external SRAM device to the internal RAM using double buffering
How do I configure STMCubeMX?
Best Regards
3 REPLIES 3
Which STM32?
DMA does not "know" whether a memory is internal or external, so you set it up as for any other memory-to-memory transfer.
Of course the DMA module has to have a path to FMC for this to work at all, this depends on which DMA you intend to use and in which STM32.
Guru
Go into DMA and a a MemToMem request.
In your code, you will need to specify the locations of each buffer, length in the call to HAL_DMAEx_MultiBufferStart.
forst
My device is STM32H743
Is there an example of a DMA using double buffering between external and internal memory?
Best Regards
