2021-07-22 5:21 AM
I have found that from the ref. manual, certain bits of ADC control and configuration bits when ADC enabled but in the drivers provided by the ST showing that they are changing only when the ADC is disabled. For reference, I have attached the screenshot. Please help me understand this topic.
Are the above are bugs in the manual?
2021-07-23 5:55 AM
2021-07-23 6:29 AM
Thank you for your reply. I file the bug report to ST on documentation. This mistake took us some waste of time and money.
2021-07-30 10:16 AM
Hello Harish,
Thanks for your reported issue.
It seems there is a typo with the docs and the LL/HAL libraries should be correct.
Your feedback is raised internally for correction.
Imen
