What are the available library and tools for BLDC control with STM32F4 ?
VGros.3
I am trying to build a BLDC controller using STM32F4. I made a board with the 6 mosfet and drivers, current sensing, Hall sensors input...
Is there a ST library for motor control ? I found differents tools (MC workbench), but they seems to be dedicated for evaluation boards. I'm using STM32CubeIDE.
Thanks for your help,
Best regards
1 REPLY 1
Gael A
Hello VGros.3,
First of all, we would like to apologize for the delay in replying to your post.
If your point is still relevant, be aware that the Workbench provides a tool called Board Manager that allows you to create your own board description for the Workbench to generate a Motor Control application. We advise you to start from a ST board description (one using the STM32F4 for instance) and modify it to your needs. This can be done in the board selection window by clicking on "Create a clone of a control".
If you agree with my answer, please consider accepting it by clicking on 'Accept as solution'.
Hope this will help,
Gaël A.
