2026-01-05 7:49 AM - edited 2026-01-05 10:45 AM
Hello. I have been researching how to use the STEVAL-ESC002V1 with a NUCLEO-F031K6 board to run a BLDC motor. The documentation mentions using the IAR Embedded Workbench for ARM 8.22, but I am programming with the STMCubeIDE and the MotorControl Workbench 6.3.2. Could someone help direct me on how to do this?
2026-01-05 8:07 AM - edited 2026-01-05 8:07 AM
I am currently looking through the Inverter tab after starting a new project in MotorControl Workbench 6.3.2, and I do not see the STEVAL-ESC002V1 listed. Will this be supported?
2026-01-05 10:29 AM
I have been following this thread and wondering if there has been any solution.
2026-01-05 7:53 PM
I have not used this board but verify if you can use the MCSDK Board Designer software to design this board and generate code.
2026-01-21 12:46 PM
Are you referring to this? https://www.st.com/en/embedded-software/x-cube-mcsdk.html
2026-01-21 12:48 PM - edited 2026-01-21 12:49 PM
BTW there are associated software files provided with STSW-ESC002V1 when I look it up online. I just don't know if I can use those files in my STM32CubeIDE firmware.
