speed feedback error in motor pilot software
‎2023-11-23 2:56 AM
I put all values of pole pair speed current etc as show in below screenshot
but while during i start the profile speed feedback error i get
please let me know what is the problem
- Labels:
6-Steps
MC Workbench
Motor Pilot
Motor Profiler
‎2023-11-23 3:14 AM
Did you check the hall sensor signals in the oscilloscope are they proper?
‎2023-11-23 3:16 AM
kindly please tell me how to check
‎2023-11-23 3:22 AM
Based on your hall sensor displacement you should be getting a waveform similar to above when the motor is running.
All the 3 hall sensor signals shall not be all low or high, then there is a problem. Tap the 3 hall sensor signals and check on oscilloscope.
‎2023-11-23 3:25 AM
how to connect u v w signals to oscilloscope
‎2023-11-23 3:26 AM
u v w means H1 H2 H3 for ref
‎2023-11-23 3:28 AM - edited ‎2023-11-23 3:31 AM
Do you use sensored (hall based) commutation?
H1,H2,H3 are hall signals
U,V,W are the inverter outputs. Both are different.
‎2023-11-23 3:32 AM
yes sir
‎2023-11-23 3:35 AM
i use sensored commutation
