OCP in custom board
‎2024-04-07 12:16 PM
I have over current protection like this in my custom board how can i implement this on motor control workbench here is my file and i'm getting eror when i try create with six step
6-Steps
FOC
MC Workbench
MCSDK6
‎2024-04-11 9:38 AM
Could you please confirm whether you are targeting 6-steps or FOC algorithm ?
Could you provide a better resolution of your schematic, and show the current sensing part.
In the WB 5, 6-step was proposed in exemple only and was not configurable through the UI.
From all ST Boards we provide, did you take one as a reference ? It is really the recommended way to be sure that we will be able to generate your own config successfully.
Cedric
‎2024-04-07 12:45 PM - edited ‎2024-04-10 9:51 AM
needs to be internal comparators with 3 different input
‎2024-04-08 2:16 AM
Hello @TKara.2,
The 6steps algo will be supported for the STM32F3 series in the next release MCSDK 6.3.0
Cedric
‎2024-04-08 10:12 AM
Hi cedric can u help me about configure the custom board i need the internal opamp type for ocp like mcsdk-5
‎2024-04-08 10:21 AM
like this
‎2024-04-10 9:34 AM
Hello @cedric H can u help me
‎2024-04-11 9:38 AM
Cedric
