2024-12-17 02:12 AM
Hello everyone!
As far as I know we have just only some limited options when it comes to choosing our MCU in MCSDK.
I am intersted in changing my mcu from a LQFP64 to a LQFP48 one, is it possible for me to choose a different, custom MCU using the board designer? if yes, what are the possible limitation? what consideration should I take into account?
Thank u all
2024-12-17 06:01 AM
Hello @MotorRunner,
Using STMC Board Designer, on the original board line, select "Clone this item" and click on "Change MCU". You will be able to select you targeted MCU.
2024-12-17 06:01 AM
Hello @MotorRunner,
2024-12-17 11:11 PM
Hey @GMA
Thanks for your reply, it really worked sir and everything is now configured cubeMX-wise, and the new MCU is STM32F030K6T6.
I will design the PCB(power+ control), and Iet you know if I could get the motor running. Thanks.
2024-12-22 12:10 AM
Hey @GMA
I just wanted to let you know that I managed to run the motor with a control board based on STM32F030K6T6 and a power board based on X-NUCELO-IHM08, so STMC Board Designer Worked perfectly.
I just got a question, how can I read VBus using MC APIs? previously I could do the job using VBS_GetAvgBus, but now I am not able to find the proper input for this function. What should I do?
Thanks a lot
